Sprocket on 2010
8 replies to this topic
  • TokioMX
Posted January 12, 2010 - 07:23 PM
Hi. Front and Rear sprockets on 2010 YZ450F same as 2009? I couldn't find any info here about it.
Thanks in advance.
Posted January 12, 2010 - 08:36 PM
Number of teeth, or is your question whether they are interchangeable?
  • TokioMX
Posted January 12, 2010 - 09:07 PM
I want to know if they are interchangeable. Thanks!
  • honda597
Posted January 13, 2010 - 12:21 AM
Yep, they are interchangeable:thumbsup:..
  • TokioMX
Posted January 13, 2010 - 04:12 PM
Thanks!
  • mxnickj
Posted January 19, 2010 - 06:39 AM
I'm assuming this means the complete wheels are interchangeable also?
Posted January 19, 2010 - 08:55 AM
At this point, I believe the rear wheels will interchange with an '09.
  • mxnickj
Posted January 19, 2010 - 12:18 PM
what about the fronts? Im looking for a spare set of wheels and was assuming they're both the same as older models
Posted January 19, 2010 - 12:39 PM
I'm not definitively certain on the front yet, but the last word I saw was that the front interchanges with the '09. If that is the case, then it's the same as the '08, which means it will fit back to '97 when the correct set of spacers for the bike is used.
The OEM rear will only interchange between '09-'10 so far. Aftermarket wheels like Talons can have an alternate set of bearings and spacers installed to convert them to the newer, larger axle.
  • Hot  36 replies
  • On January 15, 2017
  • Hot  50 replies
  • Hot  113 replies
  • 5 replies
