E-Start will not start the bike???
6 replies to this topic
  • Grandmaster
Posted May 05, 2003 - 05:42 PM
First off I would like to say hi! I have been a long time lurker here and have gained invaluable information from this board.
Now for the problem. I have a '03 WR450. Baffle is removed, grey wire pulled, snorkle yanked, and throttle stop cut. Jetting is still stock. The bike has ran fine and started fairly easily with the e-start. This weekend I installed the YZ Cam. The first few starts with the e-start fired her right up..but now she will not start with the button. She will fire right up with a single kick of the kick start but will just crank until the battery dies with the e-start.
Any Ideas?
  • Indy_WR450
Posted May 06, 2003 - 01:02 AM
The battery needs full power to crank a cold engine. There have been some battery replacements due to defective batteries. I keep my charged up with a trickle charger when not riding. Seems to work for me. I have never had to kick start mine. The battery should have a good numbers of starts before losing power.
  • RPS
Posted May 06, 2003 - 08:22 AM
I went up two sizes on the Pilot Jet and went downt to a #40 leak jet. Before I rejeted I could only start the bike by kicking it when it was cold. After rejet, I give one or two twist on the throttle and it fires right up with the E-start.
  • bfg50
Posted May 06, 2003 - 03:43 PM
I experienced the same starting problem after the YZcam installation. This is what I do. I open the throttle up 3-4 times. While e-cranking it seems to want to kick over; that's when I crack the throttle a little and it fires up.
I also noticed that it starts easier with the kickstarter.
  • Grandmaster
Posted May 10, 2003 - 10:43 AM
Woohoo! The board is back up! I wanted to say thanks for the responses. I tried the giving the throttle 3 or 4 twists and choke on method and she fired up! I guess I need to rejet and richen her up a little.
Just out of curiosity...can anyone explain why using the kick start will start the bike up with one kick without having to twist the throttle, yet with the e-start you have to develop a procedure?
  • Indy_WR450
Posted May 11, 2003 - 09:15 AM
Yamaha chose to keep the weight down by designing a light electric start motor and gear train and a small battery. Their intention is for us to use it when we stall with a warm engine. Not cold starting. I manage to use it for cold starting others cant. It is right on the edge. :)
  • xr600r
Posted May 11, 2003 - 11:22 AM
Sometimes it will fire right up with the button when cold....sometimes it wont....go figure. :)
