I need some help
5 replies to this topic
  • DP9
Posted January 06, 2010 - 11:09 PM
I have a 08 WR 450 and I just clipped the gray wire and took off the throttle stop, but now my bike boggs out. I have to keep the eons way up for it not to happen. Does anyone have any Solution for me???
  • atitagain
Posted January 07, 2010 - 05:13 AM
Did you "clip" the correct gray wire? FYI most of us just remove the wire from the plug. It is located behind the left side # plate. DO NOT just remove the throttle stop! The stock one needs to be cut to YZ specs or buy one for a YZ. Without the stop in place the throttle can stick in the full throttle position! NOT GOOD!
  • DP9
Posted January 07, 2010 - 05:49 AM
I replaced the throttle stop with the yz pin. And the gray wire, I did get the one under the seat. Unplugged it and taped it eliminating any connections
  • wondermuscle
Posted January 07, 2010 - 09:02 AM
Did you rejet the bike too? The very lean stock jetting could be the culprit.
  • DP9
Posted January 07, 2010 - 10:04 AM
No I haven't but it will be my next move. Thanks for the insight
  • wondermuscle
Posted January 07, 2010 - 12:56 PM
If you ride around sea level and have a stock exhaust I would start with the following jetting.
165 Main
4th Clip on the needle
45 Pilot
1.5 turns out on the fuel screw.
Good luck and report back to us.
