Difficult to shift into first
6 replies to this topic
  • Tropicose
Posted January 04, 2010 - 12:04 PM
Cross-posting from Dirtrider. Figured I would get a better response here...
So, I was participating in some post-Christmas hoonery around my neighborhood on my WR450 and had a low speed low side . I wheeled the bike home and put it on a stand.
The bike clicks easily into every gear except first. To get into first, it requires holding down the shifter while spinning the rear wheel until it clicks into place. I haven't fired the bike up for fear that something is damaged. Any thoughts? Would a bent shift fork still allow me to eventually get into gear?
  • bloodline
Posted January 04, 2010 - 08:35 PM
nothing wrong. carry on.
  • Yamaha_James
Posted January 05, 2010 - 08:08 AM
+1 this happens to me all the time on my ttr
  • rufusz
Posted January 13, 2010 - 04:25 AM
These type of transmissions aren't made to shift properly without the engine (or the back wheel) turning. Don't worry about it, fire it up and ride.
  • pablo83
Posted January 20, 2010 - 02:46 PM
Check to make sure the shift lever still has a tight fit on it's shaft. When it comes loose it makes shifting more difficult, particularly into lower gears. Otherwise, the bike should be fine.
  • bush_rider
Posted January 22, 2010 - 07:11 AM
Mine does it all the time, every bike does it, its nothing to be worried about.
  • YamaLink
Posted January 22, 2010 - 08:17 AM
Yep, other than crashing on the shifter side on a big ol' rock and checking the lever and splines (which should be checked for proper torque periodically anyway....I had a loose lever come off mid-ride, not fun).
