Are the axle blocks on the 2010 the same as 2009
29 replies to this topic
  • Thumper38
Posted January 03, 2010 - 04:17 AM
Are the axle blocks from a 2009 the same as 2010? Thanks
  • ZMoney520
Posted January 03, 2010 - 06:46 AM
http://www.yamaha-mo...0/0/detail.aspx
They must be different. GYTR has different part numbers for the 09 and 10.
  • MX4Life
Posted January 03, 2010 - 07:22 AM
You can't always go by part number. If they change even the color, the P/N would be different. I plan on switching my aftermarket 09's to my 2010 today. I'll let you know.
  • Thumper38
Posted January 03, 2010 - 07:33 AM
Thanks! I am just coming back to the blue side! I rode YZ's in 03, 04, 05, then went to Kawi for 06, 07, 08, 09, and now I am back to Yamaha!
  • aedwards07
Posted January 03, 2010 - 07:45 AM
Let me know if they are the same.I hate how the marks are different side to side on the 2010.
  • ZMoney520
Posted January 03, 2010 - 08:11 AM
I agree with the color and part number change but go to my link and read the description for each part number. One says it fits the 2010 and the other fits the 2009.
  • Mike546
Posted January 03, 2010 - 09:12 AM
I bought a set of Hammerhead blocks for an 09 to try on the 2010. The problem is that the block on the right side is too thick and the lock nut does not go on the axle far enough. I don't know if all the 09 axle blocks are like this or just the Hammerhead. It's too bad because with the numbers on them it would make tightening the chain much easier.
  • mediumfast
Posted January 03, 2010 - 09:49 AM
i bought a set of those too. looks like another return.....
  • Mike546
Posted January 03, 2010 - 10:39 AM
You didn't happen to buy the case saver did you? I would like to know it that fits too.
  • aedwards07
Posted January 03, 2010 - 10:42 AM
Those hammerhead blocks look great.Im going to call them tomorrow and see if they have a 2010 specific set of blocks.
  • Mike546
Posted January 03, 2010 - 11:04 AM
They don't have them for the 2010 so I asked if I could return them if they didn't fit. I was thinking of milling the right side down so it fits. I got a +15 shift lever too, I'm going out to try it right now.
  • Mike546
Posted January 03, 2010 - 11:44 AM
The shifter fits fine.
  • MX4Life
Posted January 03, 2010 - 04:31 PM
My aftermarket axle blocks from my 09 fit the 2010. But Yamaha reduced the axle nut from 32 to 30mm, now I gotta buy a new wrench.:moon:
Posted January 03, 2010 - 05:23 PM
You mean you don't have one for your steering head already?
  • Mike546
Posted January 03, 2010 - 05:49 PM
What brand axle blocks do you have?
  • aedwards07
Posted January 03, 2010 - 07:36 PM
Im not 100% on this but I believe my axle nut is a 32mm.
  • MX4Life
Posted January 03, 2010 - 08:34 PM
I'm using the Works Connection blocks from my 09. But I may order the ones show in this trend that are numbered.
  • MX4Life
Posted January 03, 2010 - 08:36 PM
Yes I have a 32mm wrench, but my 2010 has a 30mm rear axle nut. I'll price a 09 nut this week, it has to be cheaper that a new craftsmen.:moon:
  • hardcore-mx251
Posted January 03, 2010 - 10:32 PM
I have pro circuit axle blocks on order for my 2010, the guy at the shop told me they are same as 2009.. we will see!!!
Posted January 04, 2010 - 12:44 AM
I'm probably thinking of the 30mm nut on the '03, then. One of the two always works. :smirk:
Buy a Snap-On socket that size once, then whine to me about Craftsman. :cheers:
  • 9 replies
  • 0 replies
  • 0 reviews
  • Hot  79 replies
  • Hot  36 replies
