More HC piston questions?
4 replies to this topic
  • NJDirtdog1
Posted January 02, 2010 - 10:46 PM
OK i was just talking to a friend about going through with the 13:5.1 on my 03 yz450. I told him i figure by doing this it will be better for piston to valve clearance since i am running stage 1 hotcams. He seems to think, that by doing so there will be to much compression and i have a good chance of damaging the valves if i dont get stronger ones such as titanium or such. Mind you this is coming from a car mechanics standpoint, but i figured i would ask the masters. I am looking for that beastly low and mid without a bore so i figured this would be the way to go. But is it nescessary to do the valves and put ones with more guts in?
  • 426 NOOB
Posted January 02, 2010 - 10:59 PM
if im not mistaken your 03 already has titanium valves. there are people here that run cams and hi comp pistons and have no problems.
Posted January 03, 2010 - 09:50 AM
Most aftermarket high performance pistons will have more valve clearance, but your Stage I cams have no more lift than stock, so that's a non-issue. Your bike also already has titanium valves, and high-compression pistons add no more stress to the valve train, anyway. If it needs valve work, it will be independent of whether or not the piston is changed.
  • Wes Woodin
Posted January 04, 2010 - 06:37 PM
I would add stiffer valve springs or new ones.
  • NJDirtdog1
Posted January 07, 2010 - 01:14 PM
I was going to try and change the springs and seals just to do it because im sure it has never been done before but thank you all for the info!
  • Hot  113 replies
  • 10 replies
  • Hot  50 replies
  • On January 15, 2017
  • 5 replies
