Water in oil
10 replies to this topic
  • nor-calYZ426
Posted January 01, 2010 - 05:44 PM
02 yz426f gettin water in the oil. Drained the oil, put new oil in, refilled with coolent, ran bike for 3-4 minutes and all the coolent went into the oil. Bike runs fine, no loss in power, idles fine. Oil is milky white color. The guy i bought the bike from said water pump was just replaced. What do you guys think? Head gasket? waterpump?
  • Forddriver45
Posted January 01, 2010 - 06:05 PM
sounds like the water pump . If it was the head gasket it would be hard to crank and have a wet plug lol mine did.:moon:
  • nor-calYZ426
Posted January 01, 2010 - 06:10 PM
yea, i was thinking it would run crappy if it was a head gasket
Posted January 01, 2010 - 06:37 PM
The water pump can't do that, unless some "genius" decided to block off the coolant escape port.
The possibilities are:
  • Head gasket
  • Base gasket and O-ring
  • O-ring at the right crankcase cover
  • Cracked cylinder
  • Cracked head
  • nor-calYZ426
Posted January 01, 2010 - 06:53 PM
Could it be the oil seal behind the water pump?
  • Forddriver45
Posted January 01, 2010 - 06:55 PM
If the seals in the water pump go out it will pass water into the oil.:moon:
Posted January 01, 2010 - 11:24 PM
Sorry, it absolutely won't. There are two seals, one for coolant, and one for oil, with a gap between them connected to a port that leads straight down and out under the water pump. This is done specifically so that there is no chance of a leaking coolant seal contaminating your engine oil.
You can replace the water pump seals all you want, but it won't fix an oil contamination problem unless the case cover is leaking at the O-ring.
  • nor-calYZ426
Posted January 02, 2010 - 09:42 AM
I'm going try and find a diagram and see if changing the o ring helps. If that dont work it looks like I'm doing a head gasket. Thanks for the help
  • Forddriver45
Posted January 02, 2010 - 10:26 AM
It will pass water into the oil if the shaft is f*** it will let water into the motor ive seen it first hand.
Posted January 02, 2010 - 03:28 PM
No, it will not. Sorry.
  • nor-calYZ426
Posted January 02, 2010 - 05:27 PM
I MAY have found the problem. 1 of the 8mm case cover bolts is striped out right next to the O ring. Having that fixed in the morning and if it still gets coolant in the oil its a head gasket. I'll let ya know if thats the problem. Thanks guys
  • Hot  28 replies
  • 0 reviews
  • Hot  47 replies
