I'm Going for It!!! Tips/Comments Welcome!
62 replies to this topic
  • Smokeslider
Posted January 01, 2010 - 02:24 PM
#21
The bel-ray grease should work fine, I use Amsoil grease since I get the oil there too. Don't be discouraged by the motion-pro oil level tool if the plunger seems really stiff. I've seen quite a few folks complain about it and mine takes some serious leverage to pull/push fluid through it but I'm usually not in a too big of a hurry when doing my forks.
Don't want to hijack the thread, but will the smart-performance fancy fork oil change my fork settings and how so?
  • sro2004
Posted January 01, 2010 - 02:38 PM
#22
I just picked up some molly grease as an alternative. I saw in the original swingarm/linkage thread that quite a few people prefer the molly...so I have it on hand now, just in case.
  • sro2004
Posted January 02, 2010 - 05:48 AM
#23
Well...took me a lot longer than I anticipated, but my workshop (garage) is ready to roll!
Damn, that was a lot of work...
http://i608.photobuc...2004/garage.jpg
  • sro2004
Posted January 02, 2010 - 03:14 PM
#24
Dealerships all closed today? Slackers!
  • sro2004
Posted January 02, 2010 - 06:50 PM
#25
UPDATE #1
Here's some early pics. Tear down is underway.
IMPORTANT QUESTION: I'm to the point where I'm going to remove the shock. I'm going to remove the fastners on the right side of the subframe, and loosen the left side and swing the subframe over to remove the shock. My question is (I've never removed a shock before)...do I need to do anything before removing the bolts in the linkage or the top of the shock? Anything under tension in there? Thanks.
http://s608.photobuc.../tt163/sro2004/
Edited by sro2004, January 02, 2010 - 06:52 PM.
Clarification
  • Smokeslider
Posted January 02, 2010 - 07:03 PM
#26
As long as the bike is on the stand there won't be any tension on the shock. I would recommend taking the swing arm and linkage off and giving them a good greasing while your in there. It's hard to tell when the last time this was done and would be some good piece of mind.
Chad
  • sro2004
Posted January 02, 2010 - 07:28 PM
#27
Thanks Chad. Swingarm/linkage re-grease is part of the plan.
Sam
  • 97kx125
Posted January 02, 2010 - 08:22 PM
#28
just a little tip on the swingarm... It will be a lot easier to get another person to help u when you are going to reassemble it, between positioning it into the right place and lining it up its just alot easier with two people. just my 2 cents
  • sacfelix
Posted January 02, 2010 - 08:42 PM
#29
Here are a couple of videos on how to check your valves from the Hot Cams website. The procedure is pretty much the same for the 450 except for you will only have one breather tube on the valve cover and check your valve clearances in the manual to get.
http://www.hotcamsin...Video&videoid=3
http://www.hotcamsin...Video&videoid=4
  • sro2004
Posted January 03, 2010 - 04:18 AM
#30
Thanks for the input gentlemen. I'll definately get a 2nd set of hands in there during re-installation...and I appreciate the links to the valve clearance videos!
Okay...off to the garage to pull the linkage/swingarm! (although it's rediculously cold out there...it's only 39 outside! Hey, that's cold for central Florida :moon:)
Sam
  • sro2004
Posted January 03, 2010 - 08:35 AM
#31
Oh yeah! So far, so good! :moon:
Swingarm/linkage/shock came out with relative ease...
Needle bearings...here I come!
Added a few more pics...
Sam
  • sro2004
Posted January 03, 2010 - 09:25 AM
#32
Hmmm...what to do with this pretty red titanium shock spring (5.5). :moon:
Put it in my office at work as a cool decoration? :cheers:
Anybody have any ideas? :smirk:
  • myoung
Posted January 03, 2010 - 10:00 AM
#33
Looks pretty good!
Very satisfying working on your own stuff. Looks like you keep it very well maintained as well, nice work. :moon:
  • sro2004
Posted January 03, 2010 - 11:44 AM
#34
Thanks. Truth be told, I just haven't been able to ride real hard with the bike set up for a little person! Can't wait for the first ride on a better fitting bike! :moon:
  • sro2004
Posted January 03, 2010 - 02:14 PM
#35
Just finished re-greasing one of the components of the linkage (w/ needle bearings)...not too bad!
Posted January 03, 2010 - 03:05 PM
#36
If it's red, I suspect it isn't Ti (also because it came from an '09). Better try a magnet on it first. And DO NOT offer anything for sale in the forums. :cheers:
  • sro2004
Posted January 03, 2010 - 04:09 PM
#37
Yes sir, Gray. Nothing for sale here...
Per Yamaha's website for the 2009 YZ450F
Chassis/Suspension:
Titanium-sprung :moon: , four-way adjustable rear shock with Kashima-coated internals reduces friction for fantastic compliance and great handling.
  • mxracer206
Posted January 03, 2010 - 04:21 PM
#38
Good luck with your project but one thing to consider is sending out the shock for a re-valve. That is a stiff spring and even with the stock spring the bike seems to do better with more rebound danping.
  • sro2004
Posted January 03, 2010 - 05:00 PM
#39
Thanks for the input. A few others have mentioned that as well.
  • sro2004
#40
Posted more pictures...inside the linkage!
  • Hot  36 replies
  • 5 replies
  • Hot  30 replies
  • Hot  47 replies
