just got a 2007 yz 450f. What should i know for maintinence
8 replies to this topic
  • coreyl
Posted December 29, 2009 - 09:02 PM
i just got the bike today and i was wondering if there is anything specific that i should check all the time or be cautious of while working on it.
Thanks in advance.
  • Smokeslider
Posted December 29, 2009 - 09:09 PM
Check your valves often and replace your cam chain at 50 hours, if your bike doesn't an hour meter, get one and throw it on the machine. Change oil often and airfilter after every ride.. ... Enjoy!!!
  • coreyl
Posted December 29, 2009 - 09:10 PM
thanks i will pay attention to those
  • freerider_australia
Posted December 29, 2009 - 09:54 PM
biggest thing is to use a good motorcycle oil and change it often
  • nickeenoo
Posted December 30, 2009 - 05:25 AM
If you use the right engine oil there is no need to change it after every ride unless you run the bike for 7-8 hours or more. Do a search for oil; there is lots of info.
Clean air filter after every ride.
Depending on how the bike was maintained you may want to regrease all the bearings and linkages and also service the suspension.
And as previously mentioned, check valves right now and replace cam chain every 50 hours.
Nate
  • coreyl
Posted January 01, 2010 - 12:37 AM
what type would you recomend i use. the person before me used synthetic and i was wondering if i had to stay with synthetic.
  • ReedRulz
Posted January 01, 2010 - 08:17 AM
I would recomend Amsoil MCF
  • nickeenoo
Posted January 01, 2010 - 08:45 AM
You don't have to stay with synthetic but why wouldn't you? If you use a cheap oil it's shear stability breaks down quickly thus the need to change it after every ride. If you use a high quality synthetic, such as MCF, you can run it for about eight hours or three good rides. If you buy the oil right the cost is about the same for both, but much less time consuming to use a good synthetic.
  • coreyl
Posted January 01, 2010 - 02:28 PM
ok thanks for all of the help
  • Hot  36 replies
  • Hot  113 replies
  • Hot  47 replies
