05' 450 top end
3 replies to this topic
  • Joe II
Posted December 24, 2009 - 01:28 PM
I am going to re-do the top end on my 450 I bought it used so I don't completely trust it. I'm planning on piston, rings, valves. Is there anything else I should replace and what brands of the afformentioned parts work the best or should I stick w/ oem parts. Thanks in advance for the suggestions.
  • ForsheeMS
Posted December 24, 2009 - 01:46 PM
JE, Wiseco, CP, or OEM will work fine for the piston. I would inspect the valves carefully before replacing them as they may be good for another year or two. I would reccomend replacing the valve springs regardless. Also be sure to replace the timing chain.
Posted December 24, 2009 - 05:12 PM
Stay with OEM parts unless you have the experience to select and match up a full set of compatible components, and a plan for what the finished engine will do. If you're just rebuilding a stocker, Stay with Yamaha parts. They'll cost less than the upscale aftermarket parts, work better than the low cost replacements, and there will be fewer fit problems.
  • Joe II
Posted December 24, 2009 - 09:01 PM
Thanks guys
  • Hot  28 replies
  • Hot  50 replies
  • Hot  38 replies
  • 0 replies
