WR450 - Front Timing Chain Guide
1 reply to this topic
  • DQDennis
Posted December 23, 2009 - 09:25 AM
On my 2004 WR450 I replaced my damaged cylinder head and installed new cylinder rings. It’s back together now, but it will not start. The electric starter is straining to turn the engine over. I also noticed air coming in and out of the crank case tube. When I re-installed the exhaust cam, I had to push the front timing guide down a bit, ¼”. I was wondering if that is normal? I triple checked the valve gaps. They are good. Any suggestions ideas are appreciated.
  • bloodline
Posted December 25, 2009 - 09:14 PM
sounds like you got your timing one tooth off. auto decomp is not working.
