Dr D Exhaust 07 yz450
9 replies to this topic
  • pbviking
Posted December 17, 2009 - 08:31 PM
Anyone know the db level on a SS DR D exhaust? What if you add a quite core? I need to get the bike down to 96db. Thank you for your help
Posted December 17, 2009 - 09:31 PM
DRD states that their pipes, freshly packed, will pass AMA sound tests at 96db.
  • pbviking
Posted December 17, 2009 - 09:40 PM
thanks grey:ride:
I am assuming this is without the quite core? Did you find on there website?
http://www.dubachrac...&products_id=40
Posted December 17, 2009 - 10:06 PM
Yes, that's from their site, and refers to the pipe with no inserts. But passing AT 96 with fresh packing does leave a little room for variances, which could work against you.
  • racerxx276
Posted December 17, 2009 - 11:05 PM
I tried to pass 96 at a WORCS race with a newly packed dr d on my YZ450f. Had to put the quiet core in to pass.. The sound test was done by the forest service not the usual FMF guy. I blew 99 without it! Don't know how accurate the forest service guys are though....
  • pbviking
Posted December 18, 2009 - 12:10 PM
Ouch
That is what I am afraid of. Did you notice any difference with the quiet core in vs out. Power, sounds, or?
  • Wes Woodin
Posted December 19, 2009 - 12:06 AM
yeah, no way to pass with freshly packed muffler. I heard if you cut out the airbox in certain areas it will help. I had a pro friend that got stuck running a stock silencer once, due to him not passing sound check.
  • coreyl
Posted January 01, 2010 - 11:35 PM
better safe then sorry get, i would get the insert just to be sure you will pass the test
  • pbviking
Posted January 02, 2010 - 07:47 AM
true but i am hearing that with the insert the bike is still very loud 97-98 dbs...
At least that is how I read into the dr d system
  • coreyl
Posted January 02, 2010 - 02:25 PM
there is a full system on ebay now that has the quiet core included with the auction
  • 0 replies
  • 10 replies
  • Hot  36 replies
