14t and case saver
7 replies to this topic
  • cjxrider125
Posted December 13, 2009 - 10:51 PM
can i run a 14t sprocket up front with the stock case saver thingy? it barely clears the chain and it has "13T" stamped into it. so im wondering if u have to buy a different one for different size front sprockets
  • McGill
Posted December 13, 2009 - 11:59 PM
It might clear it if you use the stock chain, but if you have an O or D-Ring chain it won't. Although, it is recommended that you change chains with sprockets that way everything wears evenly.
Posted December 14, 2009 - 12:13 AM
There is no difference in the way an O-ring and a non-sealed chain will clear the front chain guide (aka "case saver") because the rollers of either of them are exactly the same size.
And also, if the chain is within the wear limit, there is no reason one sprocket cannot be changed, or both, without having an effect on wear.
As far as a 14 clearing the stock guide, it most likely will, but you'll probably need to unbolt it to install the sprocket, even if you don't run the cover on your bike. If you find it a bit tight at the front, you can file some clearance into it, or order the one for an '05 or earlier.
  • cjxrider125
Posted December 14, 2009 - 12:30 AM
im gonna take another look at it tomorrow, and if its too close for comfort i will file it down. thanks:ride:
  • Jim813
Posted December 14, 2009 - 09:14 AM
Gray is right. I am able to use the stock guide with a 14, and unbolt the guide to add or remove the 14. It's close, but it works.
  • McGill
Posted December 14, 2009 - 03:53 PM
Oh, my mistake. Thanks for clearing that up guys.
  • Wes Woodin
Posted December 19, 2009 - 12:10 AM
I would run the 14t on it. thats just me
  • coreyl
Posted December 29, 2009 - 10:15 PM
go with the 14 tooth
