2004 WR450F Front Brake Line Upgrade..
14 replies to this topic
  • aussieklx
Posted December 13, 2009 - 04:15 PM
Hi all,
Just picked up a mint 04 wr450f, low kays, full akrapovic titanium system, protapers, diamond headlight bla bla bla. Previously i had a 05 wr450f with the CR style routed brake line and the front brake was really nice. The front brake on my 04 is real spongy - my dads 04 wr250f was the same.
Whats the easiest and cheapest way to get feel and power back into the front brake? New line re-routed?
Cheers
  • redhurricane
Posted December 13, 2009 - 05:24 PM
goodrich braided line. Maybe $45 or so. You'll never go back to rubber lines again.
  • William1
Posted December 14, 2009 - 08:01 AM
I suggest you first do a fluid change. Not sure why you would think a rubber line is a problem off road. I rarely (read that never) am on the front brake so hard that there has ever been a issue with OEM parts.
Even with a SS line, the caliper has so much flex in it the improvement the line provides is negligible. If the line had to be replaced, then I'd opt for the SS one. Otherwise, it is just jewelery and that money should of been spent of getting the suspension just right.,
If you were running a super moto, then a brake line and caliper could be called for.
  • aussieklx
Posted December 14, 2009 - 01:30 PM
yer ok ill do the fluid first. Just in comparision to my 05 the front brake feel is no where as good. It was the same for my dads 04 250f. i assume this has something to do with the CR stle routing that was std on the 05?
  • William1
Posted December 14, 2009 - 02:33 PM
Nothing to do with routing. A rubber brake line is a rubber brake line. Routing has to do more with preventing another riders boot or a errant tree limb from snagging a line. Over time, the reality of some of these 'high brake lines' has been deemed pointless (too much line) and a return to a traditional route seems to be happening.
Brake 'feel' is a factor of several things.
Brake lever length, distance from the bars and stiffness
Caliper Stiffness
Brake line rgidity (rubber Vs. Stainless Steel braid)
Length of brake line (a shorter path is better, no mattter the line material)
Master cylinder design
Master cylinder ratio (piston diameter to caliper piston size)
  • aussieklx
Posted December 14, 2009 - 03:38 PM
Caliper Stiffness
hmm ok so why was the 05 front brake much better than the 04's.
- the CR routing would be shorter yes, so this would be the reason why?
  • William1
Posted December 14, 2009 - 04:22 PM
It is possible, the different brake line length is the difference but to be sure you must check:
Is the caliper identical?
Brake pads identical?
Brake rotors the same diameter and in the same condition?
Is the master cylinder identical?
Confirm via valid part numbers and/or measurments.
If they are identical and the only actual differenece is the line, assuming both bikes have fresh brake fluid and are properly bled, then the line would be the only difference. Next is to consider the lines themselves. Are they identical materials? If so, the only actual difference is the line length. As soon as you assume things, you will have inaccurate results.
  • SJMC_DON
Posted December 14, 2009 - 04:27 PM
It could be a number of different reasons...
- already mentioned is the fluid can be burnt, contaminated, etc....
- Any kind of deflection in the rotor, even the slightest can cause this despite the floating caliper.
- Bleeding is important and most times I have found the only truly effective way to do it is with a vacuum bleeder. Bleeding off at the upper banjo bolt helps too.
That brake has never been the cats meow but it works well enuf:thumbsup:
  • aussieklx
Posted December 14, 2009 - 04:41 PM
yer cheers guys, the only reason im harping on about the brake line as my dads 04 250f was the same poor (in comparison to 05) brake feel. We bled that one and no change. Anyway ill bleed it and go from there.
oh cant measure anything off the 05 cos thats whats left of it there...
  • William1
Posted December 14, 2009 - 06:10 PM
Needs new plastics and a carb cleaning. :moon:
  • woods-rider
Posted December 16, 2009 - 12:24 PM
Yeah, the first thing you should do is check the fluid and maybe replace it. Definately bleed them either way though.
  • redhurricane
Posted December 16, 2009 - 02:21 PM
There's your problem, needs new brake lines, the old ones are toast. :moon:
  • ace402
Posted December 26, 2009 - 10:24 AM
If you want a strong front brake you're gonna have to get some honda parts.
http://www.thumperta...highlight=brake
  • stev0
Posted January 04, 2010 - 04:14 AM
I have the same problem with my front. I can only just pull a stoppie if im really hard on the brakes. If i squeeze the lever i can actually see the lines expanding.
  • Brianlima
Posted March 29, 2015 - 11:35 AM
Having the same problem...spongy brake, just bought a 04 some weeks ago.
Will try the things you guys recomended
