03 XR100 Carb Specs.
4 replies to this topic
  • smallcarshop
Posted December 12, 2009 - 01:49 PM
I`m rebuilding my carb and can`t find the float level specs. Can someone help with specs.
Thanks
  • Fast Forward
Posted December 12, 2009 - 04:49 PM
Manual indicates “With the float valve seated and the float arm just touching the valve, measure the float level with the special tool as shown”
Float level: 12.5 mm (0.49 in)
  • CR125Honda
Posted April 29, 2012 - 05:41 PM
Replying to this old thread to keep bad info from being spread.
I'm pretty sure 12.5mm or .48 in may be for pre 2000 model XR100's.
On my sons 2002 XR100 (Keihin carb), I'm sure 12.5mm is not correct.
I've searched and searched and have not been able to find the correct measurement.
12.5mm would have put the float at about a 30 deg angle the the carb base.
Of all the float height's I've set in the past 30+ years, those that have a float with a flat shaped top or bottom are usually level with the carb base when they are at the correct height.
  • Fast Forward
Posted December 05, 2012 - 07:47 AM
The information was extracted from my wife's 2003 XR100 owners manual. Whether it's right or wrong I don't know (never set the float on it), it's what the manual says though.
  • GEOF
Posted December 07, 2012 - 11:27 AM
I think you will be pretty safe with 12.5mm.
CR 230F Making it Street Legal with the best Speedometer by crfer2
  • Hot  35 replies
93 honda xr100r by Honda fanatic
Dirt Bike   Make / Model Specific   Honda   XR/CRF 80-200
  • Hot  84 replies
1993 Honda XR200R bearings kit/list by Jmechler192
  • 0 replies
2002 XR200R Won't start by t_corn
  • 3 replies
Top speed of xr200r? And xr250r? by LukeSand
Dirt Bike   Make / Model Specific   Honda   XR250/400
  • 12 replies
