anyone out there had cause to pull the above sprockets off the camshafts?
tight? how did you press them on again?
also does anyone KNOW if there is a difference between the YZ & WR base gasket.
i'm checking out the cam timing, duration, overlap etc.
can anyone find comprehensive duration, timing & lift figures for the stroker cams & those from the DRZ suzuki.
any help would be appreciated.
Taffy
