Cam Chain Help-07 yz450
4 replies to this topic
  • cbesing
Posted December 08, 2009 - 08:07 PM
It appears that my exhaust jumped one tooth. I have read many posts but Here is what I noticed:
The cam chain loosens and tightens as i advance with the kick starter. When its loose, I can lift the chain off the gear slightly. When its tight, I cant lift the chain at all from the gear.
Should i replace the tensioner and/or the chain? Bike has 120 hours.
Does anyone have detailed instructions on replacing the chain?
Thanks
Chris
  • l_campionero
Posted December 08, 2009 - 08:09 PM
Your chain might be in need of replacement. I'd do it even if I suspected it. The OEM chains are relatively inexpensive. Check the chain tensioner while you're at it.
Posted December 08, 2009 - 09:17 PM
Replace them both. The two of them are less than $60.
  • alstar250
Posted December 13, 2009 - 05:39 PM
Any suggestions on a particular one? Are there aftermarket (i.e better) ones or should I just buy an O.E.M one? Thanks
Posted December 13, 2009 - 05:53 PM
Read:
http://www.thumperta...922#post8812922
