99 wr400f bog, carb jetting help
so i just picked up a 99 wr400 and after finally getting it kicked over and warmed up its got a bad bog off idle when i blip the throttle. i know you cant tell me much without tearing into the carb, but its got an uncorked stock pipe and high flow de-snorkeled airbox. im at sea level and temps are around 75F. idles fine and if the throttle is smoothly applied it pulls fine but blipped near idle it bogs bad. thanks guys
