Breaking Chains
4 replies to this topic
  • HareAndHound98
Posted April 29, 2003 - 06:31 PM
I have now broken three o ring chains. I have checked the alignment of the axle. The sprockets are not wearing out on the sides or anything like that. When the first chain broke it broke a tooth off of the coutershaft sprocket. When I removed it I noticed that the chain had been rubbing a wear mark in the case. I replaced the countershaft sprocket and have since broken 2 more chains.
The outside part of the link is just tearing in half. This bike makes really good power but I think somthing else is wrong.
Any Ideas??? :)
  • endurodog
Posted April 29, 2003 - 07:14 PM
Sounds like there is another issue at work. Possible chain adjusted to tight?? Bent or worn sprocket? Hope you get it figured out.
  • HareAndHound98
Posted April 29, 2003 - 08:37 PM
I thought maybe I was running it too tight too. So I loosened it to where it was really making a lot of noise. It broke when it was loose too.
  • Indy_WR450
Posted April 30, 2003 - 04:04 PM
Start fresh with all new chain, sprockets and chain guides. Set the chain tension and go ride! Problems will be solved.
Always replace everything when putting on a new chain. It has worked for me for the last 3 decades. :)
  • Tony426
Posted April 30, 2003 - 05:57 PM
Thats a real bummer that you broke 3 chains it should be faily easy to fix though. There is no way that these bikes will break a good quality chain if they are aligned right adjusted right and the sprokets are good . First replace the cahin and sprokets then if you have any doubt about the chain being too loose compress the suspension with one or two (if nec) people . and male sure the chain is not taught ,if it is it will break when you compress the suspension like when yoou hit a big bump under power.
Good luck
