I purchased an external stator form Baja Designs. I think they said it would produce 120 watts. This is more than enough to run all your lighting.
The external stator uses a seperate flywheel that is bolted to the original. You will still use you original stator to run power to your coil. Another coil is located inside the stator cover. To install simply lay you bike on its right side. Remove shifter. Remove the flywheel cover. Remove flywheel nut. Install the flywheel weight.
Torque bolt. Install new cover. Install new shifter. This assembly sticks out farther than stock, but it very easy to get used to.
About the 5th gear. Depending on how fast you want to go and what other riding you do you could always just change front sprockets. With 14 50 gearing on my yz I can cruise at ~50. I just purchased 15 49 sprockets. I tell you how they work out.
I think the Eline deal will only produce ~45 watts (not sure). This is not enough if you want to run high powered lights. For Acerbis headlights you can get a bulb w/ 60 watts low beam and 100 high.
Nick
[This message has been edited by npuza (edited 09-15-2000).]
