2001 cr 125 piston size??????????
7 replies to this topic
  • czapa
Posted December 06, 2009 - 06:34 PM
hi there again
so heres my little strory/problem
i bought used 01 cr 125 few months ago and wanted to have some fun with 2stroke(cause i tried 4 stroke eariler but not too big fan)
i rode it with times and noticed black oil coming in little drips from exaust noticeable on the right side of the swing arm.
my friend told me that i should check the compression on top end and most likely i need to replace the piston with the ring
i did check it and the compression was 75 psi, which is way too low , as far as i've read,
bought the new standard size piston "B" for 2001 cr 125 , put it on , and compression is just the same
while putting it back together i noticed that on the very low left side enginge cover, right under gear lever it says piston stroke 54.5 mm
is this the piston size that i need?cause when i bought new standard piston and ring i tried it in my hands in the cylinder and it felt pretty tight, but i measure it and it was close to 54 mm
what is my problem ??????????????????????????????????
PLEASE HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THANKS
  • bikesnwheelers
Posted December 06, 2009 - 06:37 PM
Piston stroke has nothing to do with the piston size. The reason for the oil is it is jetted too rich.
  • czapa
Posted December 06, 2009 - 06:58 PM
So why my compression reads only 75-80 psi? Is it normal ?
What do you think?
  • bikesnwheelers
Posted December 06, 2009 - 07:12 PM
Is your cylinder within spec?
  • czapa
Posted December 06, 2009 - 07:25 PM
Are you on chat by any chance?
What is within spec?>
i measured it with digital caliper and it reads almost 54mm
so i was hoping that the standard piston b that i bought would do the thing
thanks
  • cpr1
Posted December 07, 2009 - 01:57 PM
The standard piston bore size is 54mm. That's what you have in your hands right now. Check the cylinder for excessive wear, such as worn out plating around the exhaust port and at the top of the cylinder.
  • czapa
Posted December 07, 2009 - 05:42 PM
hi , i thought it looks okay and when i try the new piston in the cylinder felt like its pretty tight, but i guess i need a cylinder?
  • jmm18
Posted December 07, 2009 - 06:53 PM
You should meassure cylinder with centesimal presicion and buy a new piston.
For example Honda explain that the correct piston to cylinder clearance is 0.03-0.06, if you cylinder is 53.97 mm you need a 53.92 piston (0.05mm clearance)
Pro X and Vertex produce oversizes piston for worn cylinders (a,b,c,d)
Sorry for my english:thumbsup:
I got a head scratcher for you guys by dcr98
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  36 replies
NOS CR500R Uncrating by Phuzzy McPhuzzface
Dirt Bike   Make / Model Specific   Beta
  • Hot  49 replies
3 brand new in-crate 2007 CR250's to be auctioned in Vegas! by RippinCR250
  • 19 replies
CR125 Carb Cleaning Help? by Will I Am
  • 6 replies
CR125 High Revving on Start Up by Will I Am
  • Hot  28 replies
