lower foot pegs for taller rider
15 replies to this topic
  • motoskier
Posted December 02, 2009 - 02:44 PM
Does anyone know any parts or manufacturers that make a footpeg that is lower for taller riders? I am 6'2" and feel a little cramped. I bought taler bars, but was also told you can lower foot pegs a little. I have no idea how to, so if you do, let me know.
  • Krannie McKranface
Posted December 02, 2009 - 03:05 PM
http://www.imsproducts.com/ for pegs
www.gutsracing.com for taller seat kits
  • SJMC_DON
Posted December 02, 2009 - 03:19 PM
I am 6'3" with size 12 boot and I would be scared to lower my feet more than they already are...
Broken toes and feet suck:busted:
I have the GUTS racing tall seat and the BRP sub mount riser kit with OEM bars pretty happy with the ergos:thumbsup:
  • l_campionero
Posted December 02, 2009 - 03:34 PM
You'd be MUCH better off not lowering your feet closer to stumps and rocks. A taller bar and a taller seat are the way to go.
Good luck!:banghead:
  • Bandit9
Posted December 02, 2009 - 03:49 PM
The Fastway pegs are the ticket. Easily the best system. Put the short cleats on it in the low position. You can angle them "in" toward the bike, which really helps control the bike with your knee's and legs. Raced Enduros for 6 years with them and never had an issue with them being too low. Just keep those toes up.
  • motoskier
Posted December 02, 2009 - 03:51 PM
so it seems a taller seat is also a good add on. Any particular one good for 06 wr450?
  • kingjewells
Posted December 02, 2009 - 03:57 PM
I'm 6'2" 250lbs and use fastway footpegs in the low position. I had to countersink the lower mounting holes and manufacture the cap screws. I understand that fastway will sell you the capscrews now. I also use the tall Guts seat but had to build up the back of it, easly done. I am using the Scotts under the bars mount which raises the bars which are CR High bend. It all works great for me. I'm on a '08' WR, Good luck.
  • Parx_400
Posted December 02, 2009 - 08:39 PM
I'm 6,2 with size 13 boots. Lowered pegs are the way to go. Never hurt my foot. At 6,2 you only need the lowered pegs. Taller seat will raise your center of gravity.
  • TP199
Posted December 03, 2009 - 05:27 AM
Prior them offering the cap screws, you can grind the screws down that screw into the peg which willl level them off.
  • SJMC_DON
Posted December 03, 2009 - 08:37 AM
I race and ride hard... (my opinion and my friends may say otherwise:smirk:)
Anyway I can post x-rays and surgery bills from my feet getting whacked many times... 07 and up already has reduced ground clearance... I can't believe ANYONE would want lower pegs... but it's just my opinion and ergonomics are important:ride:
  • SXP
Posted December 03, 2009 - 10:29 AM
I'm with you on this one. The 07 drags it's footpegs way easier than my 99's do. Part of the problem, I'm sure, is the reduced ground clearance when compared to the 99's. The 07 looks almost toylike when parked next to my 99.
  • woods-rider
Posted December 03, 2009 - 04:48 PM
x2!
I have these and love the hell out of them!
  • speedracerlb
Posted December 05, 2009 - 07:53 PM
Well I tried to get that answered before. IM 6' 7" and on my 04 wr I cut the stock pegs (the nipple on the bottom of the peg), put the nipple on the top of the ped and reversed the springs and it lowered the pegs B/T 1/4 and a 1/2 inch. Has anyone done it on an 07-09. The pegs appears to be the same design as my 04.
Edited by speedracerlb, December 06, 2009 - 06:57 PM.
  • Bandit9
Posted December 05, 2009 - 08:31 PM
Funny you say that speedy, I was eyeballing my stock pegs on my 06 today thinking that I could somehow flip the mount and reverse the springs to accomplish this. I had great success with the Fastways, but they aren't cheap and I'm not really worried about the pegs anyway. If it is free and simple to do, then I would do it.
  • speedracerlb
Posted December 14, 2009 - 08:33 PM
Ok did the surgery on Sunday, turned out good. I took off the pegs, cut the nipples off the bottom and swithed the springs. I had to do some minor cutting of the lower footpeg bolt with a drumel, but it worked lowered the pegs about a 1/2"
  • Bandit9
Posted December 14, 2009 - 09:34 PM
Sweet. Got any pics?
