Name that clutch plate...
10 replies to this topic
  • uberfraznb
Posted December 01, 2009 - 10:27 AM
This clutch plate is out of a '99 YZ400 that I bought used. Wondering if anyone knows what they are. The owners manual is showing a symmetrical plate with no cut-out, so I am guessing they aren't stock. What is the orientation of the plates supposed to be? The cut-outs were all facing the same direction...
  • uberfraznb
Posted December 01, 2009 - 10:30 AM
Here is the picture of the plate.
  • uberfraznb
Posted December 03, 2009 - 10:10 AM
Anyone?
  • diegox450
Posted December 03, 2009 - 10:15 AM
It isn't stock. Stock ones are symmetrical as you said. Very strange!
sorry I couldn´t help!!
  • diegox450
Posted December 03, 2009 - 10:21 AM
Found this
"...The metal plates are made from stamped steel and sometimes display a very slight asymmetry, i.e., the outside of each plate may have a slight flange resulting in a rounded side and a sharp side. Put the metal plates back in the same way that the old ones came out with one proviso – if the metal plates are asymmetric they should all face the same way. Which way doesn’t particularly matter as long as they are all the same...."
In this link http://www.motorcycl....com/clutch.htm
I'll keep researching, if I find anything I'll post it...
  • jayh300
Posted December 03, 2009 - 10:25 AM
had a 99 and had to do a clutch on it... they did not look like that from what i remember... it has been a while...
Posted December 03, 2009 - 10:46 AM
I have occasionally seen plates like that, but I would advise you to replace them with a new set. Those may well be from some earlier model, and are not the ones that belong in your bike.
  • uberfraznb
Posted December 04, 2009 - 10:35 AM
I checked the Yamaha website and they are not from an earlier 4-stroke (98). I would like to continue using them, as they were working good, I just would like to know what they are how they are to be installed (orientation of the cutouts).
Posted December 04, 2009 - 11:06 AM
I wouldn't use them. But, if I did, I would stack them so that every second plate was 180 degrees opposite the one that preceded it. The next plate could be anywhere as long as the one that followed it was opposed to that one.
Remember that the clutch ends up spinning at up to 4000 RPM. You don't want to encourage an imbalanced condition.
  • usp4u
Posted December 04, 2009 - 12:35 PM
wow, I wouldn't use that in my tractor.
  • uberfraznb
Posted December 07, 2009 - 08:00 AM
Yeah, that method seems like it makes the most sense. I have no idea why they would have all been lined up when I took them out. At least alternating them 180° the imbalance will be kept to a minimum.
  • Hot  33 replies
  • 5 replies
  • Hot  79 replies
