gaines1016 said:
what are your thoughts on something like this:
http://www.sears.com...ters+%26+Meters
you are obviously schooled in the workings of multimeters. it says for 2 or 4 strokes from 1-8 cylinders but i never take the manf. word for those things. i am still a multimeter newb:thumbsup:
Features look nice, and it's obviously built to fill a niche market...
that being said, it's a 4k count meter. My Fluke, while it's on the high end of DMMs, is a 50k count.
The "count" is a measure of the resolution of the A/D converter. The measurement between the probes gets converted to a digital signal through the A/D converter. "One count" would return a binary number, 0 or 1. An "8-count" would be able to tell the difference between 8 levels. So you turn this 8-count meter on, set the range to 1 volt, and you can read 0, 0.125, 0.25...0.75, 0.875, or 1.0. The higher the count, the more resolution in the readings. And generally the wider the scales go. My old 4k count radio shack meter measured down to 100mV (0.1v) on its lowest scale; the 187 does 10µV (0.00001v). The frequency spec (20k) would have a resolution of 50Hz at 1MHz, or 20ms time.
I'm sure it's enough to do troubleshooting on vehicles, which is what it's built for, but $200 is more than I'd pay for a meter with those
specs.
The temp thing looks like a pretty standard K-type thermocouple. Cheap and easy to find. If temp measurements are a big deal for you, get an IR thermometer. Don't have the settling time of a resistive thermocouple, the readings on IR are almost instantaneous. Thermocouples are great (cheap) for temperature control systems, since they will generally heat up as fast if not faster than the parts you're working with so settling time isn't a big source of error. When you want to get the temp off a radiator hose with a thermocouple, the method of coupling and the time the RTD's been on the hose will all contribute to the measurement error. With an IR thermometer, point the thing at the hose and pull the trigger... reading shows up on it in <1sec.
Not sure about the brand either, never heard of "universal enterprises". Might be big in the automotive world, but I've never heard of them.
I'm in test/electrical engineering which is why i'm so familiar with all this...
