before i spend 250+ dollars at the TT store..
3 replies to this topic
  • yamaha king 69
Posted 30 November 2009 - 03:01 PM
i had a quick question. for the pro taper rubber mounts, it says they are for cr/crfs, and kx/kxfs. will they work on a yz 125? you guys are the only people who carry all of what i need, and no one else has the rubber mounts for stock triple clamps. so, will these work?
  • BIGBLUEKNIGHT
Posted 30 November 2009 - 03:05 PM
depends on your yz. does it have the removable bar clamps or does it have the cast on triple and bar clamp combo. if you have the removable ones, i would think that you would be in business. if you have a good local shop they might let u buy em and see if they fit and then return or they might even be able to tell u if they will fit or not.
  • Matt Tiede
Posted 30 November 2009 - 03:10 PM
Thanks for the interest. I am assuming you are referring to the bar mounts. If so, the PT CR/CRF/KX/KXF will not work. We can get you Renthal ones though.
http://shop.thumpert...t.asp?p=284&s=2
  • yamaha king 69
Posted 30 November 2009 - 03:27 PM
yea, thats what i meant. on the pro taper site, it says they are universal, i guess not. i think i saw the renthal ones searching the store, i think they were like 80 bucks. that link isnt working, so im not sure. i guess i will be getting the renthals, they will work with pro taper bars, correct? thanks for all the help, i will be ordering all the stuff tonight (most likely).
