Zuki27 said:
Well i bought the Zero 7 chest protector and cant wear them both together. The only way i can get them to some what fit together is to put the brace on and then slide the zero 7 arounf it by taking apart the starp and then forcing it back together. but i cant get it off without using a screw driver to pry the clamp off the shoulder straps cause there so freakin hard to un clamp. idk what to do.... maybe ill return the neck brace and chest prtector....
And Europa, do u think the brace had anything to do with ur collar bone breaking cause the suspenision straps are soposed to help prevent that unlike other braces wear the sit right on it. Just wondering what ur opinion is.
first off.. the leatt or alpinestar units should not touch ur collar bone at all.. if it is resting on ur collar bone.. it is not fitted right..
when fitted right.. it should be about 8th to a quarter of an inch above ur collar bone..
this is the reason for the breaks.. other then the fact that it is one of the weakest bones in the human body.
