Rear shock spring internal size
1 reply to this topic
  • GuyGraham
Posted November 29, 2009 - 12:33 PM
Does anyone know the internal ID of the rear shock spring on an 08 WR450?
I know RaceTech quotes it a 63.4 / 60.6mm
I just need to know if I can use a std off the shelf 2.5" ID (63.5mm) without issue, as I can get them for a lot less £'s than the propriety mx springs
TIA
  • GuyGraham
Posted November 30, 2009 - 07:49 AM
Well for anyone comes across this thread in future
Top shock collar measures 59.95mm dia
Bottom collar measures 58.00mm dia
A std off the shelf 2.25" (58.5mm) ID spring has an Id of 58.5mm -0.5 +1.5mm, so I'm going with a top tolerance spring, and gonna machine the top collar slightly just to get the clearance
