Ok first off let me give you an idea of my setup. I am trying to bleed the front brake and after about 5 hours I have gotten nowhere. I have blead brakes before so this is not my first time. The banjo bolt on the caliper had been removed so I went out and got brand new crush washers to make sure it was sealing as it should at the caliper. I then positioned the caliper above the master cylinder to help get the bubbles out since they like to rise to the top.
After that I removed the bleed nipple and re-applied teflon tape. And then re-installed it. I then attached my Mityvac to the bleed nipple and pumped it up to 20 in/hg I cracked the nipple open a half of a turn and the bleeding process has began.
I took extra special care to make sure the level in the master cylinder has not dropped below half full. After pulling about a quart of brake fluid through the lines with the Mityvac I sealing everything up and the lever pulls straight back to the bars as if I had not blead the brakes at all. Obviously there is still air in the system but how the hell is it getting in there. :foul: :foul:
I am beyond pissed off at this bike right now. Does anybody have any idea where I could be pulling air into the system? Is this an indication that the master cylinder is shot? If so can it be rebuilt or do I need to buy a new one?
