i just put new grips on and i didnt glue them at all and i was wondering if this is okay they are super tight so are amazingly hard to get on and off and you cant turn them at all but i was wondering if i need to glue them
no glue grips
Started by mr150man, Nov 27 2009 07:52 PM
11 replies to this topic
Posted 27 November 2009 - 07:52 PM
Posted 27 November 2009 - 08:04 PM
I dont use glue on any of my grips just and air compressor to take them on and off. Try and type like you have half a brain.
I never glued mine... not after the hassle getting the old glue off.
They slid a bit (1/4"-ish) after ~1200mi.
Not too worried about it.
Posted 28 November 2009 - 04:56 AM
I never use glue, just a bit of white spray paint, the stay put fine, and come off when they need to
Posted 28 November 2009 - 05:24 AM
You'll be sorry you didn't glue them the first time you ride in the wet.
Posted 28 November 2009 - 07:18 AM
I glue and wire mine. Since S.W. Missouri has turned into a temperate rain forest the last 2 years, that's the only way I can get them to stick at all.
Posted 28 November 2009 - 09:40 PM
I use safety wire on mine. Most newer grips have molded or printed lines where the wire should go. Just a snip and they slide off with air or grab and twist them off. Wire holds them tight.
Some use a little hair spray or WD-40. when it dries it fuses them a little.
Posted 28 November 2009 - 10:03 PM
I dont use glue and never have a problem, use a little WD40 when putting em on and use wire and they stay fine.
Posted 29 November 2009 - 05:04 AM
I've tried not using glue before. The grips always seem to twist slightly while I'm riding if I do that. If I glue them the grips don't twist at all.
