somewhere in my driveline there is a squeak, it kinda sounds like there is a rock in the brake rotor or something (i know thats not the problem, just to give you a idea) when the truck shifts it stops for a split second (because of no torque obvioulsy) the when its shifted it starts right back. it can be heard pretty easlily in town but you cant hear it on the highway, i was thinking a joint is out or something, i checked each joint for play and could not find any then i sprayed wd-40 on each one one at a time to see if that that stops anything and nothing, i noticed a little bit of oil drizzle comeing from the transfer case where the shaft comes out, could a worn seal cause the squeaking cause i am pretty sure that seal, if oil is coming outs its got to be out.
its a 02 1500 silverado
