Straightening bent kick start lever
7 replies to this topic
  • bloodline
Posted November 25, 2009 - 06:45 PM
Anybody ever try?
Mine is really annoying. Foot slips off easily.
Heat it and give it a go?
  • GuyGraham
Posted November 26, 2009 - 04:39 AM
Yep - heat it up and apply a little force
Need excessive force, then its not hot enough
Do not do it cold
  • c9buff
Posted November 26, 2009 - 04:18 PM
you can try. Just remember you are taking a chance. It may snap. If it bugs you that much give it a go but you are taking a chance.
buff
  • l_campionero
Posted November 26, 2009 - 04:32 PM
If you have bent a kickstart lever, I must ask: Are you having difficulty starting your bike? Even in '98, when some guys were breaking their kickstarters before Yamaha redesigned them, I never had any problem if I followed the procedure. I have never had a problem starting a four-stroke, as I have owned a BSA B50MX, a TT500, a YZ400F, a WR400F, and a YZ426F, all with manual decompression levers; I know how to start a four-stroke.
Good luck!
  • Bandit9
Posted November 26, 2009 - 04:35 PM
What is a "kick start lever?":smirk::excuseme: Ahh, life is good for us dirtbikers in 2009.
Put it in a vise. Make sure to use something to protect the vise from imprinting the soft aluminum lever. Put a little heat to it, hit softly with rubber mallet. Done.
  • ncampion
Posted November 27, 2009 - 09:01 AM
It's tough to heat aluminum in order to bend it. Aluminum has a very narrow melting range so you have to use enough heat to soften the metal without melting it. Without enough heat, it won't help at all, too much - junk. I say just buy a new one, they're not that expensive. Probably lots of used ones on ebay also.
  • CanadianWR450
Posted November 27, 2009 - 04:44 PM
Are you sure it's actually bent, and not just wore where it butts up against the stop when extended out to kick?
Mine wore there, and caused the kick starter to swing out too much, angling where your foot goes downward, and causing my foot to slip off.
Built it up with a little weld, ground/filed/sanded to smooth and good to go.
  • bloodline
Posted November 27, 2009 - 06:35 PM
I will look at that. Thanks.
It's an '03. Lots of broken electric start stuff at this point including the case cover that supports the shaft for the gears.
All of the electric start stuff is long gone.
