Danoflapper said:
I'd go to your local gas station and pick up some Power
Service Diesel Kleen, Howes Power Kleaner, Diesel 911, or something like that. ($5-10) The flipside of the bottle will tell you the amount of their product you need for X gallons of fuel. If you're going to store a vehicle over the winter make sure the tank is full of diesel so the condensation factor will be kept to a minimum.
Should be good to go come spring time.
Any of the products with "Clean" in them are for removing bacterial/fungal growth in the fuel system. They do nothing for preventing a fuel tank slushy.
Diesel 911 is for emergency gelling stoppage and reversal.
Being you're in bio diesel country, you're going to want to use a bio-diesel cleaning agent (essentially a fungicide/herbicide) to kill off any microbial growth already present, and prevent further growth during storage.
Dump that in, and let it do it's job.
Now, about winter storage....if there is one, pull the drain plug on the bottom of the fuel tank and let a few quarts come out....this will allow any water that is present to drain out (water is heavier than fuel, so the water settles to the bottom).
Now, add your preferred flavor of anti-gel additive to the fuel, and if you have purchased any diesel with bio blends, be sure that the additive clearly states that it works with bio, or you'll have solids in the tank.
Change the fuel filter before storage-water settles into the bottom of fuel filters, and can cause corrosion in them, and when you fire them up in the spring, that rust flows into the injectors-bad.
I've never really experienced diesel fuel going "bad" like gasoline does, but Power Service claims their "Agri Power" product stabilizes diesel fuel during long term storage. IDK, never used it.
http://www.powerservice.com/ap/
