Question about carbon fiber frame gurards
4 replies to this topic
  • yamaharichey
Posted April 27, 2003 - 02:34 PM
I'am thinking about carbon fiber frame guards but I worry that the constant rubbing of the boots will rub the shiny finish off making them look old and worn. Anyone had experiance with them?
  • ETP
Posted April 27, 2003 - 04:34 PM
Ditto that. I am really close to buying a set from Rockymountainmc.com for $75 for my WR450F, but I am also concerned how durable the material is. Has anyone found them for cheaper than 75?
  • dmp437
Posted April 27, 2003 - 11:37 PM
Check out www.carbonfiberworks.com
They have a "Tech Support" section on how to maintain the shiny finish on carbon fiber for the "new" look. They also have a gripper finish available (which I have on mine) that provides a better grip for your boots on the frame guard. They have a rough texture to them as opposed to a smooth surface so they don't need re-finishing.
  • yamaharichey
Posted April 28, 2003 - 05:11 AM
Well after reading their tech tips its obvious they do wear the finish off and you have to keep spraying a new finish on. So I'am going with aluminum. Thanks for the help.
  • TDog
Posted April 28, 2003 - 07:41 AM
I bought the ones with the gripper finish and they have really dulled up from my boots rubbing. They surface is too abbrasive. I would probably have stayed with aluminum if I had known this because I could remove them and polish them. I quess having them is better than not having them.
