Chain chewed through swingarm pivot
12 replies to this topic
  • TheHarp
Posted November 23, 2009 - 06:38 PM
I have my bike (08 YZ450) torn down to replace the bearings. I found that the chain has chewed through the chain slider and through the swingarm pivot just outside the bearing. :excuseme:
I can think of three options:
1) do nothing (replace bearing as I was planning)
2) have a shop weld it up
3) replace the swingarm
Thoughts?
  • TheHarp
Posted November 23, 2009 - 10:05 PM
Anyone know what year/model swingarm is the same as the 08 YZ450?
Posted November 24, 2009 - 08:57 AM
'07-'08 are the same PN. '06 should be interchangeable.
  • Wiz636
Posted November 24, 2009 - 09:07 AM
Wow...is this just a matter of a ton of hours on the bike and you forgot to keep a good slider on there or are you running a 12t front sprocket?
Posted November 24, 2009 - 09:13 AM
... or are you running a 12t front sprocket?
More likely a 44t rear, judging by the avatar.
  • TheHarp
Posted November 24, 2009 - 09:35 AM
Thanks....same as the WR/YZ 250/450?
I'm new to dirt bikes, wasn't paying attention to the slider wear.
Good eye.
Posted November 24, 2009 - 09:56 AM
The '07-'08 WR450 is the same, also, but none of the other alternatives you mentioned will work.
  • TheHarp
Posted November 24, 2009 - 10:25 AM
OK...thanks. :excuseme:
  • davidl9999
Posted November 24, 2009 - 10:29 AM
Why can't a shop weld it up? If it was a structural issue, it would have failed by now (I'm guessing). :excuseme:
Posted November 24, 2009 - 10:38 AM
Since he didn't show me what it looks like, I can't evaluate that. :bonk:
Probably what I would do, unless the required machine work was too expensive.
  • TheHarp
Posted November 24, 2009 - 10:43 AM
Since he didn't show me what it looks like, I can't evaluate that. :excuseme:
I don't have a picture of it. I'm sure it could be welded up, but if I can pick up a good used swingarm off of ebay, that would be the shorter/simpler path for me.
BTW, the part number for the swingarm listed in the microfiche for the 08 250F and 450f is the same. This makes me think I have a fairly good chance of finding one.
  • KJ790
Posted November 24, 2009 - 11:32 AM
06-08 250F and 450F swingarms are the same other than the chain guide mount (you would have to use an 06 chain guide on the 06 swingarm). I'm guessing it was worn on the bottom front of the swingarm pivot?
  • TheHarp
Posted November 24, 2009 - 01:34 PM
Yep...didn't notice until I had the whole thing torn down. Thanks for the additional info.
  • Hot  50 replies
  • Hot  47 replies
  • 9 replies
  • 10 replies
