09 YZ450f bog?
5 replies to this topic
  • 800xr
Posted November 23, 2009 - 08:56 AM
I have an 09 450 that's has a bog on landing that's been slowly getting worse and yesterday became so bad that you cannot ride the bike anymore as I almost went over the bars
I've ridden and raced yamaha's for 8 years so i usually can figure most problems out but this one has got me guessing.
Jetting is one bigger on the pilot & main, 48 and 165 main which were changed this spring to get rid of a slight bog and the bike ran great all summer to fall until the last 2-3 weeks now. located in MN.
I noticed this bog a few weeks ago and checked the valve clearances and found three valves on the tight side so reshimmed but still the bog is there on landing. it's not a split second bog, it looses power until you completely let off and get back on it. 1-2 seconds at times.
I'm gonna go through the carb tonight and see if i can find anything but figured i'd check to see if anyone has had this problem.
Any input would be great.
Thanks
  • xxinsaneriderxx
Posted November 23, 2009 - 09:03 AM
good idea see if anything is in the carb. i would take the carb off and clean out the bowl and make sure there is nothing broken it it. i had a quad that did that but i cleaned out the carb and it runs great now. you might need to adjust the jetting. just a suggestion
  • jlkfg
Posted November 23, 2009 - 09:07 AM
Check float level too
  • JJRace
Posted November 23, 2009 - 02:10 PM
second the float level. Lower it if anything as most YZFs are set a bit high from the factory.
  • mxracer206
Posted November 24, 2009 - 04:38 AM
You never mentioned your fuel screw setting, make sure it is around 2 turns out. Those things have even been known to fall out.
  • Ga426owner
Posted November 24, 2009 - 11:32 AM
and it is 3...the float level is off
  • On January 15, 2017
  • Hot  50 replies
  • 3 replies
  • Hot  28 replies
  • Hot  30 replies
