When letting out the clutch in 1st gear,it almost sounds like a grinding noise coming from the left side,and it only does it when the bike is cold.There must be some contraction and expansion of the metals,but how can i fix?
crf100 help please!
Started by reiny36, Nov 22 2009 03:56 PM
8 replies to this topic
Posted 22 November 2009 - 03:56 PM
Posted 22 November 2009 - 04:15 PM
When was the last time you the oil. the oil thickens up when the bike warms up and when its could the oil is thinner that could cause a grinding sound
Posted 22 November 2009 - 05:35 PM
thanks...i was going to change the oil,just got the bike,and of course the sound wasn't there when i test drove it! Hope it works...thanks for your input!
Posted 22 November 2009 - 06:39 PM
no problem try to get good oil to no cheap shit get oil form Honda
Posted 25 November 2009 - 11:29 PM
Drain the oil.
Pull the clutch cover off and look at the clutch.
Check the inside of the cover.
Most likely you will see where it is rubbing.
Posted 26 November 2009 - 09:04 AM
It might be the clutch basket pull the clutch cover a look to see if the basket has groves were the clutch rides in it
Posted 26 November 2009 - 02:45 PM
Thanks guys....but is it possible it could be the chain slipping on the front sprocket,and it only slips on certain teeth that are maybe a bit more worn,which is why it only does it sometimes?
Posted 26 November 2009 - 02:57 PM
Does your chain slip under all conditions? If so then it could be your sprocket/chain.
But, if it doesn't come off regularily then it's not the chain.
Take off the clutch cover. Snoop around... -BIG DAN:thumbsup:
