Power transfer delay - DRZ-S 2001
4 replies to this topic
  • omribe
Posted 21 November 2009 - 09:54 AM
When I'm in low rpm, leave the throttle and then come back to the thorttle I feel a knock from the drivetrain and only after a short moment the power goes to the rear wheel.
It doesn't happen if I come back to the throttle real gently, use the clutch or if the engine is in high RPM.
I did the following in the last several months:
1. Engine mounts tighetened
2. Chain tension adjusted
3. Added a missing shim to the rear arm axle (Helped reducing the problem by a little)
4. Rear wheel bearings were replaced
5. Clutch was adjusted
Any ideas for the cause of it?
I'm thinking somewhere in the gear/clutch area.
  • TypeSH
Posted 21 November 2009 - 02:54 PM
My guess is the chain tension might be wrong. You might want to post a picture of your chain.
  • fttam
Posted 21 November 2009 - 03:19 PM
Sure you aren't just really lugging the motor?
  • Vancouverpower
Posted 21 November 2009 - 03:30 PM
Mine did the same thing before I did the 3x3 and jetted it correctly. Does your bike die when trying to idle in first gear and/or die just as you start to engage the clutch?
I thought mine had a drivetrain issue too and was just living with it until the problem went away as soon as I did the 3x3.
  • E.Marquez
Posted 22 November 2009 - 04:01 AM
Stop lugging the motor, and make sure your chain is adjusted properly. What you describe is normal for any dirt bike when lugged.
