so many questions dont know where to begin...
its a 2001 drz400s.
was out riding last weekend all was well until basically it died. not sure when exactly the problem arose, but the bike did get horizontal 3-4 times (still getting used to only 2 wheels). the bike got laid down i was getting frustrated wouldnt start, killed the battery, got going, went down again and kept it running shortly after that it just died couldnt get it started killed the battery spent a good part of an hour trying to pop start it, it would start stay running and just die almost as if it was out of fuel, did that a few times finally got it going and wouldnt let the rpms drop below half throttle and it would stutter when getting on the gas but stay running. at somepoint in the midst of popstarting it we noticed the breather hose connecting the top of the carb to the gas tank (not the line with gas) was disconnected.
the air filters not as clean as it should be so its possible that there is just dirt in the carb?
the carb itself is a mystery to me i'm not sure how it works with the vacuum action from the tank so if there is a good resource out there that i can look up would be appreciated.
what adverse effects are there to having that breather hose disconnected for a short period of time. even with the petcock on prime on or res it would start but not stay running.
finally with everything assembled except for the the gas line to the carb with the petcock on on/res should ruel even be coming out of the tank, because there is though not as much as when its on prime (bike not running obviously).
thanks in advanced,
charlie
