Vehicle: 1997 Chevy Suburban with 5.7l
Issue:
-Engine runs great with throttle under 1/2 and will rev to 5000+ RPM. Push throttle past 1/2 and engine will loose power, start to surge and feel like it is running super lean.
-Engine stumbles sporadically while cruising
-Popping in exhaust if transmission is downshifted or if engine is revved freely
-Normally there are no engine codes, but if vehicle is operated over half throttle for any decent period of time, check engine light temporarily turns on and displays error codes for the EGR valve and low voltage for O2 sensors in bank 1.
-When engine light turns on, performance suffers more and the vehicle has a hard time getting out of its own way. Shut it off, turn it on, check light is off and it runs normal under 1/2 throttle.
Do I need to replace the EGR valve? Or could this be another issue that is causing the computer to throw codes for the EGR valve/O2 sensors?
