Does anybody know anything about electric motorhome jacks? Had one go bad last night:banghead::foul:. Fortunately, I have a spare one. Mine has a couple gears and a worm drive (save the jokes). I believe that a "groove pin" is sheared or one of the gears is chewed. The company that makes them does not make a repair kit and will not say who makes the parts for the jack. the maker is ATWOOD MOBILE, and the jack system is called LEVELEGS. Any help would be appreciated.:worthy::ride:
Motorhome electric jack problem (again)
Started by weathergeek, Nov 19 2009 09:07 AM
6 replies to this topic
Posted 19 November 2009 - 09:07 AM
Posted 23 November 2009 - 09:04 PM
Is this a mechanical jack or a hydraulic jack?
I've had the hydro ones rebuilt (nothing more to them than a bottle jack, really), but never dug into the mechanical ones.
Posted 29 November 2009 - 07:52 AM
Posted 29 November 2009 - 10:17 AM
Like any electrical issue maybe start a systematic check for grounds, shorts and check clean and tighten any connectors you can find. An ohm meter will be a big help. Is the controller replaceable by itself? Maybe the controller is messed up inside. Did you contact the manufacturer yet? Good like.
Posted 29 November 2009 - 02:43 PM
I concur....start at the jack connector, and work backwards in search of a short, open, etc.
Posted 29 November 2009 - 05:59 PM
weathergeek said:
Thanks guys. I will try that.
Also, something else....if it starts to do it again, I'd rig up a jumper wire directly from the batter to the jack and see what happens.....if the jack operates properly with the jumper wire but will not with the controls, that rules out the jack as the malfunctioning component.
