Newbie jetting question? Help please
1 reply to this topic
  • ovrtimeoffroad
Posted November 18, 2009 - 12:20 PM
98 wr400... I just bought it and not sure what was done to it in the past but exhaust is stock now..
pulled carb off and cleaned it but jets seemed a little off..
82 STARTER JET
40 PILOT JET
160 MAIN JET
Bike will start on first kick with choke in but immediatly stalls out...
If I pull the choke out.... it sounds like it has no chance of starting at all
I put in a new plug already.
Is the starter jet to rich and if so, what range does the starter jet effect?
is it only for starting or is it for idle also
ALSO: With the air/ fuel screw turned all the way in and idle screw all the way up it would not idle... IT KEPT STALLING
Any help would be greatly appreciated as im trying to ride on Friday
  • ovrtimeoffroad
Posted November 18, 2009 - 01:36 PM
Got if figured out for now...
drained all the fuel and cleaned the carb again and it started up with the choke and eventually idled with about two turns out
