drz400e handle bars for giants? help!
21 replies to this topic
  • kmas
Posted 18 November 2009 - 09:39 AM
Ok guys, Im 6'6''. I have stock bars and want to raise them and possibly replace them. If and when i do this, what bar/height, brand. I know Im going to get the adapter that raises and moves forward, but the bar has me wondering. So, anyone tall out there that can help suggest set up would be great! thx in advance.
Matt
  • l_campionero
Posted 18 November 2009 - 09:41 AM
Look at a Freestyle/ATV bend bar or a Renthal Jimmy Button bend.
  • Brooksy
Posted 18 November 2009 - 01:21 PM
Yup! A set of "Jimmy Button's" or "Travis Pastrana" bend bars and a set of BigDR's risers(http://www.barrisers...rdrisers78.html), and you're in business.
  • kmas
Posted 18 November 2009 - 03:06 PM
are you guys tall? does this turn the bike into a frankenbike? thx for info, those risers look cool
  • l_campionero
Posted 18 November 2009 - 03:08 PM
I am only 5' 11 1/2" tall, but I sit tall in the saddle. I have gotten used to lower bars, but I have used the Jimmy Button and the ATV bends in the past. They look weird, but work just fine.
  • Brooksy
Posted 18 November 2009 - 06:15 PM
I'm only about 5' 10", but drive standing up most of the time. The risers I posted actually are mounted on one of my friends bikes. His name is DenDrz and is actually the designer of the risers that Barrisersonline sells. He is about 6'3" or so. I have a Topar top clamp with risers on my KLX. These I also got from DenDrz, who bought them from Eddie. Small world, eh?:ride:
  • 1978Rider
Posted 18 November 2009 - 06:59 PM
Scotts stabilizer is expensive but nice to have and you get "free" risers ! Combine those with Pro Taper Contour "Woods High" bars and you have much higher bars. I like em high because i stand up a lot for hare scramble - woods riding.
Stock vs. Scotts:
Image from Scotts website:
  • kmas
Posted 18 November 2009 - 07:45 PM
thats sick, I need to stick to budget though, pipe, jet kit, kick start, and then bars if im lucky
  • Goebz
Posted 18 November 2009 - 08:44 PM
I am 6'4" with 33" inseam so I am tall on top. I got a GPR setup similar to the Scotts undermount on 1978Rider's post. I got Protapers in a Henry /Reed bend and I feel they are a little low. You dont need to get a Stabilizer to get risers but you must have risers to under mount your stabilizer.
You can rise with standard bars. Rise and set back, Rise and set forward, and rise set back/forward with a different bend. You could skip the risers and just go to a higher bend but that would only make a 10-20 mm difference.
If you were ever near Ohio, I would let you ride mine and feel it out. If I were to do it again I would go with a CR Hi bend and the risers I have.
Most riders are looking for a comfortable height while standing and although I have long arms, I would need a much higher bar to be truly comfortable.
Check Wheeling Cycle Supply for a Zeta riser setup that is high quality for a very reasonable price. If you change bars, be sure to get a new throttle tube and grips because the stock throttle tube is Vulcanized to the grip. Not a problem if you keep the stock grips but mine were worn and i had to grind the rubber grip off the plastic throttle tube. I added some pillow tops and like them a lot.
  • kmas
Posted 19 November 2009 - 12:57 PM
wish i had some coin for the bigdr risers, those are nice, anyone got some used bigdr risers?
  • wvdualsport
Posted 19 November 2009 - 01:39 PM
Up and forward will make a huge difference. I run barrisersonline risers and CR HI bend Renthals. I like the setup.
  • kmas
Posted 19 November 2009 - 02:56 PM
what kind of hand guards are those?
  • kmas
Posted 20 November 2009 - 08:12 AM
Does barriseronline make a forward riser for 1 1/8 bars?
  • obrianmcc
Posted 20 November 2009 - 09:44 AM
Pastrana FMX pro Tapers
  • kmas
Posted 20 November 2009 - 10:25 AM
are those bars 7/8 or 1 1/8, because if i understand correctly the barrisers.com risers are for stock 7/8 application. thx for help
  • kmas
Posted 21 November 2009 - 07:33 PM
anyone? 1 1/8 barrisers.com risers?
  • wvdualsport
Posted 21 November 2009 - 08:52 PM
Not anymore.
  • Just John
Posted 22 November 2009 - 06:14 AM
I have not used them,just another option.
http://www.motorcycl....org/drz400.htm
  • Goebz
Posted 23 November 2009 - 09:29 PM
To raise a stock bar 22mm
Uni Mount Kit Above with clamp that joins all 4 bolts
Billet upper triple with risers and clamp
Different height risers available for above
Wheelingcyclesupply.com
  • kmas
Posted 01 January 2010 - 12:27 PM
just snagged up some barrisersonline risers for 45 new!!! im stoked......not tapping into my pipe funds so bad
