just putting together my 07 s with bb kit, hot cams, tt fcrmx39 and mrd/ssw ive got the jd jet kit are the needles in the kit better for my set up than the emn needle? and is 170 mj to mutch ? should i chang to the 42pj with the kit or stay with the 45pj that the carb came with ? i know im asking a lot but im lost on this one and want to be able breakin the new parts properly all help is appreciated thanks ps elevation is 500ft :worthy:
jd needle better ?
Started by motothump, Nov 17 2009 07:03 PM
5 replies to this topic
Posted 17 November 2009 - 07:03 PM
Posted 17 November 2009 - 07:08 PM
i have a JD needle and it is fine. James actually traded carbs with me and it came with a 42 pilot, 160 main and one of his extended fuel screws. i'm running a yosh rs-2 pipe, k&n and 3x3 and it was perfect. i ended up with the same settings he had on it when i took it out of the box. James' stuff is the best!
Posted 17 November 2009 - 07:13 PM
decide if you want to use the kit or not and i will give you a setting.
the JD kits are handy as the come with the parts and instructions/guideance.
DRZ jetting is so refined that the JD kit is not a must have like on some bikes.
its up to you.you will be satisfied either way.
Posted 18 November 2009 - 02:47 PM
eddie thanks for the response, yes ill use the kit what do you recomend for jetting and needels?
Posted 18 November 2009 - 03:27 PM
162 main jet
200 main air jet
jd blue needle
clip 3
45 pilot jet
pilot air jet removed
2 turns fuel screw
ap linkage wired solid
ap timing screw in 3/4 turn
200 main air jet
jd blue needle
clip 3
45 pilot jet
2 turns fuel screw
