Which Stator?
9 replies to this topic
  • wrpete
Posted November 17, 2009 - 06:19 PM
I have a 1999 yz 400 and want to fit a dual sport kit to it. Baja designs web site say to use a wr426 stator but dont mention which year. So can someone tell me exactly which stator and fly wheel I would need?
I have found a stator and flywheel for sale here off a 2002 wr 250 which has the same part number as the parts off a 2002 wr426. Would it fit?
Thanks
Pete
  • veewdave
Posted November 19, 2009 - 12:18 PM
I have the same question and cannot find any answers! Can someone help?
  • umu24013
Posted November 19, 2009 - 10:25 PM
I have a 1999 yz 400 and want to fit a dual sport kit to it. Baja designs web site say to use a wr426 stator but dont mention which year. So can someone tell me exactly which stator and fly wheel I would need?Pete
You'll need a '00 WR400F/'01-'02 WR426F/'01-'02 WR250F stator. Part number 5NG-85560.
You should be good with a flywheel off a '98-'02 WRF (250/400/426).
Pete
Should be a direct bolt on.
  • wrpete
Posted November 20, 2009 - 04:09 AM
Cool thanks for your reply. I am also assuming that if I do the stator mod on the pink wire as detailed on the electrosport web site I should be able to use my YZ 400 CDI.
Thanks
Pete
  • gumbellion
Posted November 20, 2009 - 06:29 AM
Thanks
Pete
That is correct.
Posted November 20, 2009 - 07:07 AM
The current listing for a 2000 WR400 is 5GS-85560-50-00 for the stator. An '01-'02 shows the 5NG-85560-00-00 (5NG-85560 is an incomplete part number). These two should interchange, but the 5NG...50 is likely to be an upgrade over the 5GS.
The flywheels also show two different numbers for a 426 and 400, with 5BF-85550-00-00 listed for the '98-'00 400, and 5NG-85550-00-00 for the '01-'02 426. These may interchange, although you should check carefully, and you may want further confirmation. If I had to simply guess what the difference was, I'd imagine it had to do with the greater electrical compatibility of the flywheel and stator as a set.
  • umu24013
Posted November 20, 2009 - 06:02 PM
Improved magnet?
Posted November 20, 2009 - 07:25 PM
Improved magnet?
...or the placement of the timing signal lug, the trigger coil, ...
Not sure, really.
  • toyotanick
Posted January 30, 2012 - 05:31 PM
just a little did bit of info that i feel like i should input. about a year ago a buddy of mine's 03yz450f was having stator issues and didn't have the money to buy a yz450 stator. luckily i happen to have a 1998 yz400f stator laying around and and we compared them. The two were exactly the same so we installed the 400 stator onto the 450 and it has been running and charging the bike for at least a year. i am wondering if, since this worked why wouldn't it work the other way?
Edited by toyotanick, January 30, 2012 - 05:32 PM.
  • toyotanick
Posted January 31, 2012 - 06:46 PM
what does this stator with this wire mod put out wattage wise? I'm hoping for 100watts so that i can run my h.i.d
  • Hot  47 replies
  • Hot  113 replies
  • 5 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
