Ignition flap?
4 replies to this topic
  • CoolHands
Posted 17 November 2009 - 03:57 PM
sorry quick question I can't find the answer to. Does the DRZ ignition switch have a little flap (sprung-loaded usually) like most other bikes? Mine doesn't seem to have one, even when I look with a torch. So it's open all the time IYKWIM. The keys been getting a bit sticky lately so I wondered if a missing flap is part of the prob
cheers!
  • Jeff_in_RC
Posted 17 November 2009 - 04:05 PM
I know my US version has one, is yours stuck to one side? Maybe take a toothpick and pick at it to see if you can free it up?
  • CoolHands
Posted 17 November 2009 - 04:10 PM
ok thanks I'll take another look and try & fiddle with it
  • rubbersdown
Posted 17 November 2009 - 04:25 PM
go to your local auto store and get some dry graphite lube. just put a little right inside your ignition and it will lube it up so your key dont stick. dry graphite lube is the ONLY thing that you should ever use to lube your ignition by the way.
  • GuyGraham
Posted 18 November 2009 - 04:46 AM
NO it doesn't have a flap
It needs one though, as every time you wash the bike aor leave it out in the rain, water gets into the ignition switch
Mine always used to play up big time after I washed it
Now I spray GT85 down it, after every wash which has stopped it mis-behaving
