I hear V Force reeds help as well. Moose
Torque Spacer, exhaust spacer, PC pipe is what I did and pre 06 bikes you can alter the timing manually.
I did those, it helped but not that much. I found the PC pipe worked the best for low end. The FMF literally did nothing. the FMF made it a bit broader and running a 14/48 also helped make it generally more rideable with less shifting and less wheel spin if you ride in the mid range more. It will bog if you are really low in the rpm's.
Moose also sells a thin base gasket .012 I think that raises compression which helps low end performance.
