Cuchara Red said:
Supercharger, right? Sounds good but my first thought is how to drive it and where to mount it. Since there's no handy pulley anywhere and things are kinda tight back around the countershaft, plus anything driven off the chain might also have to move with it I'm thinking it might not be so easy. But, it's a new thought and who knows. Maybe some kind of machined adapter to drive it off the left end of the crank (through the timing hole). Street only.
Might be good for a brainstorming session where no ideas are laughed at (until the end). :p
If I were to do such a project, or try to, I would drive 1/2 of a turbo that would produce the flow at the rpm I could drive it. I would drive it from the starter drive hole with the starter drive gear sprag (one way roller clutch) installed backwards. I would mount the carb sideways, find some oil source and let it return to the breather box. Add a kickstarter, and lots of cash for r+d and there you go. Not that I have been thinking about this or anything. My way you could spend/would spend lots more than Eddie building you a proven motor, but not as much of an education. Good luck, CFC
