Pulling the motor
2 replies to this topic
  • thunderone
Posted 16 November 2009 - 07:11 PM
Do you have to pull the motor to put in hot cams. I'm going to the MC shop monday to have new 39 crf carb, hot cams and exhaust put on.
  • chrisf608
Posted 16 November 2009 - 07:19 PM
Motor will not have to be removed for any of the modifications you have listed. Should make some good power :thumbsup:
  • r1usn
Posted 16 November 2009 - 07:54 PM
You will not have to remove the engine. For the cams, just check in the faq section and look at valve clearence check. In order to change the valve clearence you have to remove the cams. That should help.
