2008 Yamaha Yz450 Waterpump problem
2 replies to this topic
  • desertracer49
Posted November 14, 2009 - 06:23 AM
On my bike once I start it up the coolant leaks out of a hole on the bottom of the waterpump cover. It looks like it would be behind the impeller. Could it be the oils seal behind the impeller? Please respond.
  • ProjectDIRT
Posted November 14, 2009 - 08:28 AM
if its leaking from the whole the water side seal is bad the whole is an indicator.
  • micahmorgan
Posted November 14, 2009 - 07:01 PM
Sounds like the ol' water pump seals. I recommend you do a search in the yamaha forum for weep hole and/or coolant. You'll find lots of help. You need to replace the seals and likely the shaft too.
  • 10 replies
  • Hot  38 replies
  • Hot  113 replies
  • 0 replies
