fly wheel weight...srry if i sound like a noob
6 replies to this topic
  • crazyjimmydrz400sm
Posted 12 November 2009 - 03:16 PM
ok correct me if im wrong but these little babies provide the motor with more centrifucal force which means you can lug around without stalling better right?
  • gospeedracer51
Posted 13 November 2009 - 08:08 AM
Correct. They also improve traction because it slows how fast the engine can rev.
  • scriberman
Posted 13 November 2009 - 03:44 PM
More rotational mass, slower to accelerate and decelerate.
  • Coolidge
Posted 13 November 2009 - 03:56 PM
Increases Inertia
  • daled
Posted 17 November 2009 - 02:31 PM
my 68 BSA 441 had an amazingly heavy crank shaft assembly. (like adding huge fly-wheel weights)
i could dump the clutch at an idle in first gear and the bike would not stall !
LOVED IT.
down side?
whack the throttle open and the motor went from, pop,pop,pop to BANG,BANG,BANG, without increasing speed much at all..
LOVED THAT TOO.
  • isaac338
Posted 19 November 2009 - 06:28 PM
http://en.wikipedia....ment_of_inertia
MOI = resistance to change in angular motion (ie how hard it is to make it spin faster or slower).
Increasing mass increases MOI which means it's harder to stop the flywheel spinning. Simple!
  • highmarker
Posted 19 November 2009 - 07:02 PM
LOVED THAT TOO.
great anaolgy, LOL. I had a 500 husky with a (stock) heavy crank and flywheel that you could dump and it would just lay there on the ground and wind up all the local vegetation in the rear wheel and sprocket, didn't stall though.
My crf250x runs the heaviest one I could find. Took away that "snap" that made it easy to lift the front wheel on a throttle wack. Now i have to lightly touch the clutch, but when i do the all that stored flywheel energy picks the wheel up even farther.
